Results 1 to 13 of 13
    Roger Frazee's Avatar
    Roger Frazee Guest
    Default Something different for the forum
    Thought I would share something with all of you that I was asked to come take a look at today. So I think I'll start this story by posting a couple pictures of this piece of equipment and see if anyone can guess for what it is used. Then I'll give more details and pictures.
    No Jerry ... it isn't something you troll offshore to attract sharks....
    Default Re: Something different for the forum
    That's easy. They use those on the prairies at the drive-in movies so people can plug in their block heaters.
    Roger Frazee Guest
    Hi John
    Nope but that ain't a bad idea.... I'll probably leave this open till tomorrow evening then if someone doesn't guess what this is I'll fill in the blanks.
    To add a teaser ... this was supplied as a rental to the customer who needed it.
    Chico,Ca
    They are used as portable power at "events" (music or whatever),notice the camlock connectors on the back of the panel? Those are used to supply power to the panel.
    That GE panel hinges seem to have seen better days by the looks of the replacement piano hinge.
    Michael Garrity's Avatar
    Michael Garrity Guest
    As mentioned above it is a portable panel for event use or construction site use.
    James Kiser's Avatar
    James Kiser Guest
    Portable service hooks up to generator
    MaMa Mount's Avatar
    MaMa Mount Guest
    Has this guy never heard of a picture resizer. I hate it when someone post pictures within there post like this cause it makes if difficult to read.
    When I was a roadie for Ted Nugent we used portable panels like those all the time.
    Quote Originally Posted by MaMa Mount View Post
    ... I hate it when someone post pictures within there post like this cause it makes if difficult to read....
    Yeah. It's reely anoyying when sumone makes there poste har to reed.
    Roger Frazee Guest
    A picture with the cover removed.....
    Ft. Myers, FL
    Geeze, I havent been on here hardly at all in the past year, and one of the first posts I look out Mama rears her **** head.
    Paul Kondzich
    Ft. Myers, FL.
    MaMa Mount the rodie
    You know what ticks me off to no end is a man pretending to be a woman on a home inspection forum.
    Yes...Ole Tony Mount has screwed up on many occasion and been bagged for who he/she really is but insists on playing Mama Mount.
    Then the only thing we hear is about something he doesn't like about someone else. This is about the worst identity issue I have ever seen. I wonder if Tony inspects in a dress?
    Roger
    There is nothing wrong with your post or pictures. I personally would rather have them like that so you don't have to click on them to blow them up. Great pics!
    Well Ted (or is it Teddy) it's no worse than a woman pretending to be a man.
    Ouch !!!
    Roger Frazee Guest
    Ok I see I wasn't paying attention to what the motive was for mama's post.
    So to redo the post
    Rollie wins the prize he was the first correct reply. and yes the piano hinge is a nice touch...
    When I first walked up on this equipment I wanted to see it with the cover off.
    These are some of the problems I pointed out. These are all shown in the attached pictures.
    1.) Metal cabinet not bonded to the grounding bar.
    2.) Thin copper ribbon wrapped around power conductors where they terminated into the lugs including the neutral conductor.
    3.) Knockouts for the two 4x4 boxes at the left and right of the panel top did not have clamps for the nm-b and the sharp edge has cut thru the outer sheath and about half way into the grounded leg of the 4x4 on the top left.I didn't capture a picture of this.
    When the customer returned this for corrections they installed a machine screw thru the bonding hole in the ground bar that was too small and instead of threading it into the bonding hole they lock washered and put a nut on the back side. They also said this wasn't necessary but would do it to make them happy. They would not remove the copper ribbon around the power conductors as this was required to properly secure the wire in the lug ... jeeez
    They did install new nm-b to the top 4x4's and used nonmetallic snap in clamps in the knockouts.
    Anyway my advice was to return the equipment and spend the dollars for a 200 amp professionally made portable entertainment 'distro' cabinet. They are expensive ( $1700.00 ) but the customer is starting a stage lighting entertainment business so money well spent. They decided to do that and it should be in overnight delivery. I'll post a picture of it later. Anyway here are the pictures again as originally posted.
    In the picture showing the grounding bar .. the machine screw used to bond the cabinet is just under the robertson screws. The empty hole at the bottom is where they removed the bonding strap to the other neutral bar when they separated the ground from the neutral for a 4 wire feed. This panel has been used in dozens of events with the metal enclosure not bonded before they were asked to do so yesterday.
