Results 1 to 2 of 2
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default High altitude waste line
    At 7500 feet the water is lighter so it can drain better.
    Atlanta, Georgia
    Default Re: High altitude waste line
    Anytime you see the flex pipe, you know you need to look harder at everything else as well.
