Thread: deck stairs
    Jun 2008
    Default deck stairs
    How do you like this stringer attachment?
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: deck stairs
    JDJ: Wunerful, wunerful . . . .
    chris mcintyre's Avatar
    chris mcintyre Guest
    Is this really that bad?
    Apr 2008
    Western Massachusetts
    Simpson LSCZ. They're not that expensive but most big box stores don't carry them therefore deck "builders" aren't likely to use them.
    Mickey Elias's Avatar
    Mickey Elias Guest
    Definitely should have a mechanical fastener such as a angle plate.
    Apr 2008
    Toenails are actually sufficient (well, when done properly they are - those in the photos do no fit that category) as the angle of stair stringers works to transfer some of the loads laterally at the deck. The problem with toenails is that I've never seen them done properly. Wrong fastener size, wrong angle, wrong spacing, wrong number, insufficient header, and insufficient top riser height are the usual culprits.
    I always use mechanical fasteners to attach stair stringers to the deck, whether they're inside or outside stringers. Why gamble?
    A.D. Miller Guest
    CW: Not necessarily true. A nail's holding power is a function of its diameter, how far it penetrates the wood, and the type of wood it penetrates.
    And a framing nail is not just a framing nail. There are hand-driven nails, both common and box, and then there are the more often seen pneumatic nails with smaller shanks and some with clipped heads. All of these nails perform differently regarding their withdrawal strength load values.
    http://senco.com/pdf/facts/ner272.pdf
    It is also notable here that Senco, for one, recommends only stainless steel fasteners for framing exposed to the elements, especially when using pressure-treated lumber.
    CW: I have, but no longer remember when.
    Apr 2008
    Yes, I have their stainless nails. Cost more than the tool if I recall...
