Results 1 to 2 of 2
    Default Laminate Floor Inspection in Fairbanks, AK 99709
    We have a laminate floor in Fairbanks, Alaska that needs to be inspected. We would provide you with checklists on what to look for. Pictures, RH/Temp Readings and moisture readings with a non-invasive meter required. This is a fairly easy inspection that should take 15-20 minutes. All information will be upload to our website.
    Contact Ron Gould (rgould@inspectsolutions.com) or Scott Heath (sheath@inspectsolutions.com) for more information. You may also call (888) 854-0946.
    Michael Garrity's Avatar
    Michael Garrity Guest
    Default Re: Laminate Floor Inspection in Fairbanks, AK 99709
    It's a long drive from NY but I could pick up the checklist on the drive out.Would it be a flat rate or mileage?
    Do you mind if I bring my dog?
