Thread: Gas sniffer
    Apr 2008
    McKinney Texas
    Default Gas sniffer
    Anyone use a gas sniffer electronic device. Unfortanetly for me, I am not blessed with a good sense of smell, and often I have not detected the scent of natural gas, when others have. I see the gas sniffers on the market, but they are several hundred dollars. Anyone use one of these devices, etc and welcome any comments.
    Gene
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Gas sniffer
    Gene
    GS: You can get a TIFF 8800A for under $150 if you look around.
    Apr 2008
    McKinney Texas
    Hi A.D. Thanks.
    Do you find you use the Tiff quite often? and find it reliable ? Thanks for the tip, I did locate one for $176.
    Gene
    A.D. Miller Guest
    Hi A.D. Thanks.
    Gene
    GS: I use it only to verify what I already smell. Keep looking, I know they can be found for <$150.
    Michael Garrity's Avatar
    Michael Garrity Guest
    A canary works quite well
    Purchased a Tiff when I first started in 1991. Rarely used it and was religated to the shelf. Through it out last year.
    If I remember correctly pipe dope will also give false reading.
    A.D. Miller Guest
    Quote Originally Posted by Michael Garrity View Post
    MG: Except that the proportion of natural gas in air required to produce the collapse of a canary is about 65%.
    A.D. Miller Guest
    RW: Depends on what the dope is smoking in that pipe.
