Results 1 to 4 of 4
Thread: Blade Fuse Size
    Erwin, TN
    Default Blade Fuse Size
    This might be a stupid question but, here goes. Is this blade fuse a 100 AMP fuse or a 200 Amp. Does the (2) 100 AMP fuses make a 200 AMP system?? Thanks
    Default Re: Blade Fuse Size
    100 amp, 230Volt assuming that is a 230 volt pull out fuse block.
    It is twice the voltage and power but the amperage is still limited to 100 amps.
    On The Mason-Dixon Line
    Those fuses are 250 volt 100 amp.
    Until you get into medium and high voltage work , Fuses for AC come in 2 voltage ratings. They are 600 volt and 250 volt.
    250 volt are to be used on anything under 250 volts ( 240 , 208 volts)
    600 volt are to be used on anything OVER 250 volts and UNDER 600 volts.
    ( 480 , 277 volt) (This is something to keep in mind for those of you who do commercial inspections were there is 480 volt electrical systems)
    NO the 2 -100 amp fuses do not make a 200 amp system, it is 100 amps at 240 volt.
    Think of that pull out as a 2 pole circuit breaker. In this case a 2 pole 100 amp circuit breaker. It's only good for 100 amps.
    And while you are at it ... keep in mind that many insurance companies WILL NOT INSURE a house which has fuses panels in it, meaning that the panel will need to be replaced just to be able to get insurance.
