    Mark Aakjar's Avatar
    Mark Aakjar Guest
    Default Vent stack on boiler
    Are dampeners needed on all boilers inside the home? I came across a boiler that had solid piping coming off the boiler through the roof.
    Default Re: Vent stack on boiler
    We'll need more info please. Type of fuel, age of unit, metal vent or masonry, length of chimney,etc. Is it a single family res? Water for heat or ..?
    Mark Aakjar Guest
    Sorry. It's a Wellmclain, aprox 1989, oil fired boiler. In a single family home two storys located in basement
    A damper is a good idea but it doesn't have to have one. Back in 89 a damper was still more of an 'option' item for many WM boilers. Some of the larger size boiler didn't allow for dampers.
    You could run the model # and see if a damper is an option for this boiler. 89, I doubt it has a built-in control circuit. Installing a relay and damper is pretty easy for a good HVAC tech.
    David Bell's Avatar
    David Bell Guest
    It should however have a barometric damper.
