    Default two water service lines?
    Strange new construction condo/townhouse has two, count 'em, two copper water service lines in the basement. I'm waiting for the condo association to return my call.
    Michael Garrity's Avatar
    Michael Garrity Guest
    Default Re: two water service lines?
    For different units? Sprinkler system?
    Quote Originally Posted by Michael Garrity View Post
    ...Sprinkler system?
    Of course. Brain not working. Thanks.
    I disclaim fire suppression systems, but, just a thought - is PEX acceptable for such a system?
    Apr 2007
    state of jefferson
    yes. check their listings.
    Yes, but for God's sake, man, that was 4 days ago!
    It's Friday,make it a double.
    John,
    I know you also wrote up all that improperly supported PEX going to the manifold.
    I'm not sure that blue PEX is listed for sprinkler use, thought it was not??
    Last edited by Jerry Peck; 03-12-2010 at 08:15 PM. Reason: added the color blue to text to assist the reading impaired :-)
    REHAU Introduces FIREPEX Residential Fire Sprinkler System: PEX System Designed for Fire Protection Professionals
    .OOPs Didn't read as I should have " Blue."
    John,
    Yes I did. I've never seen it done right.
