Thread: Toilet shut off valve
03-12-2010, 09:11 AM #1
Any thoughts on why these were installed. Several toilets in the home were like this.
03-12-2010, 09:34 AM #2
Re: Toilet shut off valve
future hand held bidet?
03-12-2010, 12:43 PM #3
It has been posted here before where someone added a kitchen sink sprayer or hand held shower head at this location for a makeshift bidet.
03-12-2010, 01:24 PM #4
No telling why, other than what Bruce posted. When they correctly secure the PEX and the valve you might recommend that they remove it...
03-14-2010, 08:48 AM #5
Kitchen sprayer connection for cheap bidet. I have seen a few in various ethnicity / religion homes. I always recommend removing due to cross contamination issues.
03-14-2010, 10:12 AM #6
What you have now are dead-ends (health issue/plumbing violation) which are open to contamination.
Poor man's bed pan/potty-chair/medical comode/diaper rinser/colostomy bag washer. The plumbing codes address the proper method of installing same, this is not one of them.
Other possiblity wrong way to install an "insty-hot" feed to temper supply water (warm it) to prevent condensation on the toilet tank.
Open port no vac breaker, no check, syphon, and dead end to valve is no good - especially in such a contamination prone zone below flood rim of toilet bowl!
Unsupported/unprotected pex through floor exposed no protection from damage - plastic disk/flange on floor NG either, S/B metal.
