Results 1 to 15 of 15
    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default skylight in valley
    note the skylight corner in the center of theis valley. its not leaking that i could tell but what do you say about this?
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: skylight in valley
    That is, hands down, the stupidest skylight installation I have ever seen. If it does not leak now, it will soon.
    New Mexico
    Oh my. I hope you got a good chuckle out of that one. They are just begging for a leak. Is it at least over a shower or tub?
    I would tell the client, this skylight will leak, it's just a question of when.
    chris mcintyre's Avatar
    chris mcintyre Guest
    its not leaking that i could tell....
    That's because it wasn't raining.
    Is this the roof of the house or an out building?
    I would change your statement to "it's not leaking" YET.
    Other than being completely and totally wrong ... and that it will leak sooner rather than later ... I don't see what the problem is ...
    Nov 2009
    St Paul, MN
    I'd call it out for repairs by qualified contractors.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Was the skylight framed like this as well----- from today.
    Healdsburg, CA
    If this is a contest for stupid skylight installations can I enter this one?
    Jerry McCarthy
    Troy Eskew's Avatar
    Troy Eskew Guest
    I think you just took the lead Jerry. Not only for the skylight installation, but for that poor roof design as well.
    Healdsburg, CA
    Troy...... wait.... here are 3 more entries into our "Stupid Skylight Installations" contest.
    Jerry McCarthy
    Troy Eskew's Avatar
    Troy Eskew Guest
    These skylight installs/repairs are making my brain hurt.
    I love this one, I can hear the roofer (or the homeowner) every time this skylight leaked.
    "It can't be the skylight leaking because we sealed it, it must be coming through the run of shingles above the skylight"
    "Still leaking! It must be coming through the run of shingles above where we have sealed."
    "Still leaking! It must be....."
    Frank Suchodolski's Avatar
    Frank Suchodolski Guest
    The roof installation is incorrect as well. If you are gooing to drive fasteners through your metal roof, they should only be through the raised ribs, NOT 2" from the valley center.
    Frank Suchodolski, RRO
    Quote Originally Posted by Frank Suchodolski View Post
    Partially correct.
    MANY metal roof manufacturers specify fasteners in the pan area at the bottom of the panels ... admittedly NOT 2" from the center of the valley - more like 6" back from the center of the valley, but still one (sometimes two) in the pan area at the valleys and the overhangs.
