    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default no vapor barrier
    house 1980 wood frame wood panel siding.
    The house never had any water proofing/vapor barrier installed. You pull the siding back and you can see insulation and framing. Obviously not good, and i recommend installing but was the code always to do this?
    Colorado Springs, CO
    Default Re: no vapor barrier
    So there is no exterior sheathing?
    Bruce Breedlove
    www.avaloninspection.com
    no but that is not uncommon. we put wood siding right over the house wrap here.
    I do not know when a water barrier became a requirement, however I see it on houses built in the early 60s, maybe earlier.
    Not real uncommon to have T-1-11 siding over wood frame without house wrap back then, but it probably should have at least had building paper (felt) installed behind it ("should have" being key).
    My house up here is wood frame (1978 vintage), I believe I recall having seen felt when I looked inside the vented area behind the fireplace, 1/2" plywood, then 1/4' or 3/8" cedar plywood with cedar battens on it to look like rough-sawn cedar board and batten. There are a few houses in my neighborhood which are T-1-11, one of which is a 5,400 sf house around the corner from ours - what a shame to install T-1-11 on houses like that.
    Of course, most also have FPE panels in them too ... (At least there is no aluminum wiring.)
    That's an indication of 'Good builders gone bad' ...
