Results 1 to 1 of 1
Thread: quality install
    ray jackson's Avatar
    ray jackson Guest
    Default quality install
    This customer called my company for routine maintenance. All that junk on the coil is attic insulation. Yes that is the powering wiring you see as well. I told the customer that the way the high voltage wiring was ran was unsafe. He said he was going to call the installing contractor to have them fix it. He did let me clean the coil though.
