Thread: truss cut
    Jun 2008
    Default truss cut
    The attic trusses are at 24" on center as usual. 1987 construction. The hatch is narrow enough that it could have been placed between the trusses without cutting one of them.
    I shared this because its the first time I've found one that could have been placed without the need for cutting. I wonder why they did it. Maybe it was moved from another location than the original construction.
    Another member of the cut truss was split. It flexed quite a bit when I pulled down on it.
    Default Re: truss cut
    Oh John! You'll drive yourself crazy if you start doing this.....
    "I wonder why they did it."
    The last one of these I ran into was a broken truss in an attic and I just couldn't figure it out..... until I went back to the garage and saw the seller's dismantled climbing wall and anchors. Sure enough, the main pulley that likely people hung from had likely been attached to the broken truss.
    Houses should come with warning labels.
    Most people don't know that trusses are engineered so they make room for whatever they need.
    Here is one I did yesterday that those dang web members got in the way of storage. I think they knew something about trusses as they added to top plywood on the altered ones.
    Quote Originally Posted by Gary Burnett View Post
    Nice try but no cigar Mr. Homeowner.
    John,
    I came across the same thing yesterday.
    rick
