Thread: Equipment grounding conductor
03-30-2010, 08:48 PM #1
Doe the ground bar in the panel on the right require and equipement grounding condutor. A four cable feeder was note used.
03-30-2010, 08:58 PM #2
Re: Equipment grounding conductor
Trying to get some better pics.
03-30-2010, 10:45 PM #3
03-31-2010, 05:38 AM #4
Roger,
That is the case. Thank you, I thought so, but had a brain lapse yesterday.
03-31-2010, 05:12 PM #5
03-31-2010, 05:14 PM #6
Jerry, Not. That is just my utah accent, Note
03-31-2010, 05:28 PM #7
Jerry do you have xray vision
03-31-2010, 05:37 PM #8
03-31-2010, 07:16 PM #9
03-31-2010, 08:46 PM #10
Roger,
In the left panel is see the feeder coming in from the top near the left corner, and I see two blacks, what might be a white fuzzy shadow in the back, and near that fuzzy shadow is another even fuzzier shadow which might be the grounding conductor.
The center panel feeder is also coming in from the top near the left corner, it is clearly SER cable with two blacks and a white behind them, with stranded aluminum outer wrapped ground pulled off to the left side. I believe that is the fuzzier shadow I see in the left panel too.
The right panel is what I was referring to and it is shown most clearly with the feeder coming up through the bottom - which happens to look a lot like the feeder going out the bottom of the center panel - and it has a black, red, white is behind the black and bent back behind the red, with what looks like the grounding conductor coming out and bending to the left.
At 1,000% zoom it starts to get a bit pixelated to make much out, better at 200% zoom, beyond 300% it starts to get fuzzy and pixelated (is that even a word and even spelled correctly if it is?).
03-31-2010, 11:43 PM #11
You could be right I just can't get it clear enough to tell
