    Default Here's a good one
    Lets close the utility closet doors right up against the front of the Cat. 1 furnace!
    Default Re: Here's a good one
    And look at that thing. Looks like the operation of the unit and the venting leaves nothing to be desired. Oh well. When the heat kicks on, on one of those cold nights they just get a little extra heat when the door starts burning.
    Especially if those are metal louvered doors as they appear to be as they are frequently lined with cardboard on the inside where the louvers are not located (and even sometimes behind the louvers ).
