Results 1 to 15 of 15
    Apr 2007
    WESTMINSTER CO
    Default AFCI BREAKERS REQUIRED IN NEW SERVICE PANEL INSTALLATION
    HEY GUYS NEED A SPARKY HERE
    OK having a battle with some local sparkys. i have seen new istallations on main breaker boxes lately that do not have afci breakers installed.
    in denver every city has a different NEC that they follow.
    but should they not be installing afci breakers in all bedrooms and now even most living areas. if they just put in new service panel.
    thanks for your help
    also please read my last thread on aluminum wire repairs and purple wire nut--need help on both issues
    cvf
    Default Re: AFCI BREAKERS REQUIRED IN NEW SERVICE PANEL INSTALLATION
    Scratching my head here ... I thought "Denver" was a city?
    Not necessarily as "the circuits" were already there. Now, install a "new" circuit and the answer would be "yes".
    Apr 2007
    WESTMINSTER CO
    HEY JP
    yeah Denver is a city with lots of municipalities is what i should have said.
    so afcis only if new circuit as per new bedroom added. i get it
    thanks
    happy easter
    cvf
    Charlie,
    You got it.
    Think of it like this: I inspected rough electrical in a condo today in which the exterior front porch area has been enclosed and they added many new lights and receptacles - those NEW 'parts' of the circuits will require AFCI protection as the new "outlets" require AFCI protection, which will result in protecting those entire circuits.
    JP,
    CHARLIE does not believe in punctuation or upper/lower case letters.
    Apr 2007
    WESTMINSTER CO
    sorry GUNNAR
    bad on typing. i sometimes leave cap key on and oh well better inspector then typer. will work on it. but hope i still get message across
    happy easter
    cvf
    Roger Frazee's Avatar
    Roger Frazee Guest
    cvf
    I am assuming here that these 'sub-cities' ( sorry Jerry I just had too.. ) that have a different or amended NEC are not amending the requirement for afci ? Or maybe the argument is afci is required but the sparky's are saying because it is new work on existing dwelling that the afci is not required ?
    Apr 2007
    WESTMINSTER CO
    THAT'S IT ROGER
    lots of non permit finished basements going in and bedroom, and who knows if they put new circuits in. so i just write it up afci recommended or required get electrician out.the sparkies get pissed. the ones who didn't pull permits
    cvf
    Chico,Ca
    If the panel is replaced, then no AFCI snake oil required, add or extend a circuit (depending on NEC edition adopted) then AFCI's are required. ATM, California is 2005 NEC.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    CVF: 2008 NEC is one thing. Has the local AHJ "adopted" that version of the NEC without modification or exclusion?
    Heck ... the Texas TREC SOP requires I inspect ALL houses to the current NEC and IRC. Many current "new home construction" does not / will not meet the requirement as the local AHJ has yet to adopt the current code cycle.
    Then there are the dang local AHJ exclusions to the current code cycle. Assuming you can get your hands on them.
    But ... it is still better than AT&T in many ways!!!!
    Quote Originally Posted by Nolan Kienitz View Post
    Huuuuuuh
    Nolan Kienitz Guest
    TM -- CVF and I are both AT&T alums. I was with AT&T Labs for 20 -years doing construction and commercial inspections. My last many years with "T" were on classified projects (I had a very high clearance) doing builds/inspections on a contract "T" had with FBI, Secret Service, NSA ... etc.
    Another life ... another time.
    Now you are talking interesting stuff. My son in-law is still with the FBI. Can never get the involvement behind ones self !
    Apr 2007
    WESTMINSTER CO
    NOLAN
    how did you know i was with at&t. interesting. did we cross paths. or did you seee me smoking stuff in the at&t mens room.
    cvf
    Nolan Kienitz Guest
    CVF - We traded messages at some time in the past over this past year.
    My gray matter just happened to kick it out.
    I used to live in Denver and built a few sites for TCG as they were being purchased by "T".
    Sites were down in the Denver Tech Center.
