    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Water heater TPR valve
    Does the discharge tube on a TPR valve have to be PVC or copper. I am not sure what type of material this was, almost like garden hose. I could not find a rating.
    Default Re: Water heater TPR valve
    Not almost like... that is a garden hose. No, it's not rated, and since GE water heaters are exclusive to Home Depot, the whole install is likely DIY.
    Dom.
    P2803.6.1 Requirements for discharge pipe.
    The discharge
    piping serving a pressure-relief valve, temperaturerelief
    valve or combination valve shall:
    13. Be constructed of those materials listed in Section
    P2904.5 or materials tested, rated and approved for
    such use in accordance with ASME A112.4.1.
    TABLE P2904.5
    WATER DISTRIBUTION PIPE
    MATERIAL STANDARD
    Brass pipe ASTM B 43
    Chlorinated polyvinyl chloride (CPVC) plastic pipe and tubing ASTM D 2846; ASTM F 441; ASTM F 442; CSA B137.6
    Copper or copper-alloy pipe ASTM B 42; ASTM B 302
    Copper or copper-alloy tubing (Type K, WK, L, WL, M or WM) ASTM B 75; ASTM B 88; ASTM B 251; ASTM B 447
    Cross-linked polyethylene (PEX) plastic tubing ASTM F 877; CSA B137.5
    Cross-linked polyethylene/aluminum/cross-linked polyethylene
    (PEX-AL-PEX) pipe ASTM F 1281; CSACAN/CSA-B137.10
    Cross-linked polyethylene/aluminum/high-density polyethylene
    (PEX-AL-HDPE) ASTM F 1986
    Galvanized steel pipe ASTM A 53
    Polybutylene (PB) plastic pipe and tubing ASTM D 3309; CSA CAN3-B137.8
    Polyethylene/aluminum/polyethylene (PE-AL-PE) composite pipe ASTM F 1282
    Polypropylene (PP) plastic pipe or tubing ASTM F 2389; CSA B137.11
    Stainless steel (Type 304/304L) pipe ASTM A 312; ASTM A 778
    Stainless steel (Type 316/316L) pipe ASTM A 312; ASTM A 778
    Insulation on the hot pipe is too close to the draft hood.
    The flue pipe doesn't look like it's secured to the draft hood.
    Just a note in addition to the other information given in the posts above ... "PVC" is not allowed for that use.
    I suspect you were meaning "CPVC"?
    David Bell's Avatar
    David Bell Guest
    Check G E website for product manual, they allow insulated pipes down to the top of the heater
    David Bell's Avatar
    David Bell Guest
    The garden hose makes it much easier to get that pesky leak outside. Nevermind that the water pressure in the home is over 100 PSI and the heater is set at High. Just a guess.
    But the insulation is too close to the single wall vent.
    I inspected a home the other day that folks lived in. Both gas water heaters water temp was between 165 and 170
    Yes, I turned it down. Told the owners and they thought the water temp should be that high. They stated that many times they were just about scalded almost instantly .
    "I inspected a home the other day that folks lived in. Both gas water heaters water temp was between 165 and 170"
    You do understand that the "T" in TPR stands for Temperature, and is set at 150 deg.
    Ahhhh.......really?
    I did not write everything I got into with the owners. I just never completed what I was writing and what I went over with them. Got called away and hit send before leaving.
