    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Messy electrical
    Do you include this in your reporting. Also is Romex permitted to be run along supply ducts.
    mike huntzinger's Avatar
    mike huntzinger Guest
    Default Re: Messy electrical
    can you explain when this is located, i can see the plumbing can be damaged and should be behind sheetrock so should any romex wires
    Las Vegas, NV
    Absolutely. Electrical wiring unsupported and subject to abrasion and damage, PARTICULARLY where it contacts the edge of the metal duct, creates fire and shock hazard.
    Yes, as long as it is not secured to them.
    Beacon Inspection Services
    Like Beacon On Facebook
    This is in the mechanical room, house was built in 02.
    dana1028's Avatar
    dana1028 Guest
    Quote Originally Posted by Bob Knauff View Post
    Would you be kind enough to support that statement with a code section?
    Quote Originally Posted by dana1028 View Post
    Dana,
    Which part?
    You mean screwing the NM cable straps to metal duct or flex duct?
