    Kevin Luce's Avatar
    Kevin Luce Guest
    Default Re: Crawlspace vent fan
    It shows that I have posted this at 7:48 pm when it is 2:48 pm. 5 hours difference. I look to see if I can change this or I'll just have to remember the 5 hour difference.
    Kevin - re the time, click on User Cp at the top left corner and then Edit Options. For some reason when I set it to Greenwich minus 5, it was still an hour off, for east coast. So I set it to minus 4 hours.
    And, I seem to have spell check. If I spell something wrong it gets underlined in red, but only after making a space after the word.
    Capistrano Beach, CA
    Quote Originally Posted by Kevin Luce View Post
    Hi Kevin,
    John is correct. Go to the User CP (User Control Panel) on the top horizontal menu bar in there select "Edit Options" OR on the right side of that some horizontal menu select the "Quick Links" drop down and in there go directly to "Edit options".
    On the options page you will see " Date & Time Options".
    Set "Time Zone"
    Set "DST Correction Option:". This may be off by an hour due to the new DST date this year check it again on the day we were suppose to do it.
    Thank you John for also posting these tips.
    I thought there was going to be a spell check?
    In the upper right on the text box that I am typing in now there are 3 icons. One is spell check, the next is to enlarge the text box (keep clicking to make it bigger or smaller) and the 3rd is to switch editor modes.
    I will try to move these posts to the "Help" section.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Kevin Luce's Avatar
    Kevin Luce Guest
    Thumbs up Re: Time stamp and spell check
    I think I got It!
    Thanks!
    Last edited by Kevin Luce; 04-01-2007 at 06:35 PM. Reason: To see what it looks like
