Results 1 to 3 of 3
    Kevin VanderWarf's Avatar
    Kevin VanderWarf Guest
    Default The new board looks great
    However; it's kinda of a bummer that I can't find of the topics the last couple of days.
    Was all of that wiped out or is there a way to keep it going.
    Also, did we loose our little status icons, with the number of post.
    Either way, the new board looks great, but as with any significant change it takes getting used to.
    Ah, I didn't realize I was posting this in the HVAC section. oops
    Tim Moreira's Avatar
    Tim Moreira Guest
    Default Re: The new board looks great
    Kevin,
    I spent a lot of time this morning and afternoon reading through things.
    Somewhere on here Brain stated that the old board is currently being used as an archives for all of the old posts. He is currently in the works to merge them onto the new board. You can still access it by going to that section, IE electrical, plumbing, etc and then clicking on the "Sticky **** (number of posts for that section) Archives Posts" under Brian's picture. It will then take you to the old board and you can view the old stuff.
    The old number of posts are also said to be merged onto this board in the future.
    Did not see anything on the little post icons.
    Just my two cents worth on what I have read somewhere on here.
    Capistrano Beach, CA
    Hi Kevin,
    Thank you!
    As Kevin has said, the first post of every thread is a "sticky" meaning it will always stick at the top of the list. That sticky contains a link directly into that particular section on the old board. If there was a conversation going on there that I cut short I apologize. There just wasn't any way to import the thread from that board.
    You can go over there and copy the first post of a thread and start if fresh here.
    Sorry for any inconvenience but in time we will be rockin and rollin on this board too.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
