Results 1 to 4 of 4
    Jon mackay's Avatar
    Jon mackay Guest
    Default Cut rafter repair
    Is there a minimum length requirement to sister a rafter like this? I thought it was supposed to run the entire length of the rafter.
    Default Re: Cut rafter repair
    You are right, that is a joke, not a sister.
    It is not even a distant cousin of a sister.
    In our area they reccommend 4 feet each side of the cut and nailed and or bolted, some inspectors require gussets when tuss'. the one you are looking at is for sure not good!!
    Rolland Pruner Calif.
    "They" being a design professional, correct?
