    Jon mackay's Avatar
    Jon mackay Guest
    Default Sagging garage door framing
    I could not pinpoint any issues such as wood rot that would cause this sagging condition. The header seemed to be a bit on the short side. It appears to have been this way since construction.
    Can anyone identify a cause or issue with this or would you write it up as poor framing practices?
    Default Re: Sagging garage door framing
    Undersized header. That is a bearing wall with the weight of the floor, roof, walls above.
    Jon mackay's Avatar
    Jon mackay Guest
    No floor or walls above, just a roof..
    Could be just poor framing. One side of the garage may be just slightly higher than the other side which would place the header out of plane.
    rick
    Jon mackay's Avatar
    Jon mackay Guest
    Rick,
    That is what I am thinking also. Everything seemed to be in place.
    The crowns where matched when the header buildup was done and then they put the crown down instead of up and it continued to sag more over time. The lumber looks big enough and if it is then that is more than likely what happened,
    It does look a little lower on the left side of the picture but there is still a good bow in it.
    I see that now after looking closer, I could have sworn I saw the wall extending up for a second floor.
    Ted's theory sounds about right.
    Jon mackay's Avatar
    Jon mackay Guest
    Yes it was noticeable there is no distortion.
    Apr 2008
    Western Massachusetts
    There's something about the siding being out of parallel with the garage door opening, and the discoloration on the plate under that header that has me wondering if the siding and garage doors are replacements covering up damage from water intrusion. Does it look like the posts on the right (from the outside) look like they've sunken or compressed a bit?
    The garage door counterweight bar is off plane from the the header. Without being there we don't know which one it is. Looking at the garage door closed would help. I don't really see a bow as much as I do just different slopes. That's a pretty narrow opening, a pretty large header and a minimal load on it (no upper floor, etc.). I vote for it being built off-level or some movement on one side of hte garage.
    Jon mackay's Avatar
    Jon mackay Guest
    No compression anywhere, I settled on crown placement.
