    New Mexico
    Default panel spec question
    Today I was reading the specs on an ITE panel from 1985. On the ground bar, it stated "Copper - One # 14 - # 4 AWG and two or three # 14 - #10 AWG."
    So, I think that what they mean is the main lug can hold a wire from # 14 up to a # 4, and the terminal screws can take up to 3 wires if they are between #14 and # 10. Is that what others think that this means?
    Default Re: panel spec question
    Those things always confuse me. Often, there's a chart that shows where certain wires can be placed (larger or smaller screw slots), but I can't read the "labal" in your picture.
    I just hope that the "labaler" can wire a house better than he can spell.
    mike huntzinger's Avatar
    mike huntzinger Guest
    sometimes i see the extra wire going to the gas meeter nearby or to the water pipes
    That means:
    one #14 to one #4 copper
    one, two or three #14 copper
    one, two or three #12 copper
    one, two or three #10 copper
    "one, two or three #14 copper
    one, two or three #10 copper"
    Does that also mean any combonation of these?
    Chico,Ca
    That note applies to the ground bar kit.......
    New Mexico
    That means:
    I see it now. For all of the holes on the ground bar, if there is only one wire, it can be up to a # 4. If more than one, it must be no larger than a # 10, and there can be up to three of a # 10 - # 14 in each hole. I wouldn't have put the word "and" in there, if that is what they meant. To me it reads that you can have a #4 wire, and three more # 10 wires, but not one more # 10, since it only says "and two or three...", not "one, two or three".
    No.
    Thanks Jerry
