Results 1 to 2 of 2
    Nampa, Idaho
    Question Neutrals and Grounds combined at floating bus.
    Can neutrals and grounds be combined if the bus bar is not bonded to the panel. This panel is downstream of main service panel.
    Default Re: Neutrals and Grounds combined at floating bus.
    Neturals and grounds are required to be on seperate buss if not the service equipment.
