Thread: Exterior LVL
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Exterior LVL
    I could not find anything on this. Do you know if this type of LVL is rated for exterior exposure.
    Default Re: Exterior LVL
    No - does not appear to be approved for exterior use based on #5.3 of the attached PDF; Never mind, I can't figure out how to attach a PDF, I'll PM it to you in a minute.
    I did some research on exterior LVL's a few years ago. From what I vaguely remember exterior rated ones are much darker in color. Sorry don't remember anymore than that.
    Sep 2008
    Texas
    Do you see the label where it says ESR 1210? That means there is a report on file with the ICC. Here is the link to the report.
    http://www.icc-es.org/reports/pdf_fi...S/ESR-1210.pdf
    It doesn't directly address rating regarding exterior exposure.
    Sep 2008
    Texas
    So that means that it is not rated for the exterior!
    Well that would make sense
    Matthew, if you read #5.3 in the ESR, it states, dry condition of use, covered and no more than 16 percent moisture content.
    I don't live in your location but I doubt Utah weather would comply with that. Therefore, NOT approved for exterior use.
    Sep 2008
    Texas
    The main point I was making is that you can find information on an item when it (the item) has the ESR number on there.
    Markus, thanks. I can't seem to bring that report back up.
