Thread: Burner
    Holladay, UT
    Default Burner
    My client and I were curious about the use of this burner on range top. The burner has a small piece in middle that can press in.
    http://acloserlookslc.com/
    Default Re: Burner
    Seems that I remember something similar on OLD ranges from the 60's that had something similar billed as the "burner with a brain".
    Default Re: Burner
    Temperature sensor in a cast iron burner. Common in the 80's as well.
    Default Re: Burner
    Temp sensor is correct, very common older units.
