    Bryan Wilcox's Avatar
    Bryan Wilcox Guest
    Default pre-cast concrete steps to home
    I am looking for specific info on wether there are specific guidlines or installtions practices on precast concrete steps, or "floating steps" when thery are installed to an entry door to a home. More specifically, what is the minimum allowable gap between the home and the floating steps. Specific code reference would also be greatly appreciated
    Default Re: pre-cast concrete steps to home
    The only thing I can find pertaining to this is tread width requirements. The gap between the house and the steps could affect the tread width. Here is the code reference.
    1009.3.2 Dimensional uniformity. Stair treads and risers
    shall be of uniform size and shape. The tolerance between
    the largest and smallest riser height or between the largest
    and smallest tread depth shall not exceed 0.375 inch (9.5
    mm) in any flight of stairs. The greatest winder tread depth
    at the 12-inch (305 mm) walk line within any flight of stairs
    shall not exceed the smallest by more than 0.375 inch (9.5
    mm) measured at a right angle to the tread's leading edge.
    To save repeating everything all over again, check this thread out: http://www.inspectionnews.net/home_i...tml#post127781
