    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Grade sloping towards retaining wall
    Is there slope requirements for grade along retaining walls. Seems like common sense
    Richard Stanley's Avatar
    Richard Stanley Guest
    Default Re: Grade sloping towards retaining wall
    Drainage is an important component that should be incorporated into the design and construction.
    Sep 2008
    Texas
    R401.3 Drainage.
    Surface drainage shall be diverted to a
    storm sewer conveyance or other approved point of collection
    so as to not create a hazard. Lots shall be graded to drain surface
    water away from foundation walls. The grade shall fall a minimum of
    6 inches (152 mm)within the first 10 feet (3048 mm).
    Exception:
    Where lot lines, walls, slopes or other physical
    barriers prohibit 6 inches (152 mm) of fall within 10 feet
    (3048 mm), the final grade shall slope away from the foundation
    at a minimum slope of 5 percent and the water shall
    be directed to drains or swales to ensure drainage away from
    the structure.Swales shall be sloped a minimum of 2 percent
    when located within 10 feet (3048 mm) of the building
    foundation. Impervious surfaces within 10 feet (3048 mm)
    of the building foundation shall be sloped a minimum of 2
    percent away from the building.
    R403.3.3 Drainage.
    Final grade shall be sloped in accordance
    with Section R401.3. In other than Group I Soils, as
    detailed in Table R405.1, gravel or crushed stone beneath
    horizontal insulation below ground shall drain to daylight or
    into an approved sewer system.
