    Apr 2007
    WESTMINSTER CO
    Default WATER HEATER AND BOILER VENT PIPES
    HEY ALL
    found this in crawl space today. two water heaters vented together but this opening in vent stack. same thing for boiler. am i right that this is spewing co into crawl. my co detector did read low levels when water heater fired. or is this a right config???
    cvf
    Question Re: WATER HEATER AND BOILER VENT PIPES
    unlisted horizontal draft hood. That and the single walled connector should not be there.
    Listed and approved draft hoods only and B-vent only in crawl space.
    Condition of chimney?
    clean out?
    Liner?
    Clearances to combustibles off that single walled pipe?
    Support?
    Screws?
    Dariusz Rudnicki's Avatar
    Dariusz Rudnicki Guest
    Default Re: WATER HEATER AND BOILER VENT PIPES
    If this is on the water vent pipe, it will act as a second draft hood, and double draft hoods are not permitted. It dilutes exhaust gases and might cause spillage into the crawlspace.
    May 2007
    Frankfort, KY
    That's all it's gonna take for me to give it the red tag.
    Nice even rusting too.
