Thread: ASCIs
    Sep 2008
    so so, California
    Default ASCIs
    Does anyone know what year AFCIs started to be made mandatory in bedrooms? Sorry about the typo.
    Default Re: ASCIs
    Do you mean AFCIs? 2003
    Default Re: ASCIs
    Does anyone know what year ASCIs started to be made mandatory in bedrooms?
    2002 and then the end of 08 or beginning of 09 for the rest of the home.....maybe. All of that is maybe due to who actually adopted what when.
    Sep 2008
    so so, California
    Default Re: ASCIs
    How do I confirm this? Via NEC? I only have 08'
    I just need something that says the year it was mandatory.
    Default Re: ASCIs
    National Electrical Code® (NEC®) Requirements
    NEC 1999
    The National Electrical Code® (NEC®) first mandated the use of AFCIs in 1999 for the protection of branch circuits supplying bedroom receptacle outlets. The effective date was January 1, 2002.
    210-12. Arc-Fault Circuit-Interrupter Protection
    • (A) Definition. An arc-fault circuit interrupter is a device intended to provide protection from the effects of arc faults by recognizing the characteristics unique to arcing and by functioning to de-energize the circuit when an arc fault is detected.
    Default Re: ASCIs
    Keep in mind it usually depends when the permit was applied for so there can be some variation.
    Chico,Ca
    Default Re: ASCIs
    It is a major issue when on what code was adopted at the time tthe permit was issued, some juristictions are quick to adopt a new code & others are way behind in adoption of a code. But if CA would never adopt the 2008 NEC it would not hurt my feelings (From what I understand it takes effect in JAN) just because that AFCI's are snake oil that no one in the field can prove they work, unlike GFCI's which are a proven & inexpensive device.
    Sep 2008
    so so, California
    Default Re: ASCIs
    Thanks guys. Great responses.
