    Clint White's Avatar
    Clint White Guest
    Default Gas Pipe on Roof ?
    http://i310.photobucket.com/albums/k...o/adell006.jpg
    Wasn't sure what section to put this in (roofing, HVAC, ???)
    I ran across this gas piping yesterday. It extends straight up through the soffit, across the roof, and is run down into the home at various points. (gas furnaces, stove, dryer) I have NEVER seen gas piping run across a roof like this. Sent this to my HVAC guy who agrees that it is "non-standard" install, but NOT ILLEGAL.
    Would like your input if you have a moment.
    P.S. No need to pick the rest of the picture apart, I know the roof is trash, I had to wear a raincoat IN the HOUSE....no joke
    Clint
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: Gas Pipe on Roof ?
    Black Pipe ? How was it attached ? Any photos ?
    Best
    Ron
    ... Any photos ?..
    The photo url is at the top of the post. I missed it too, at first.
    David Bell's Avatar
    David Bell Guest
    No supports, pitch boxes, one of those jobs you just kinda shake your head at.
    What's a pitch box?
    David Bell's Avatar
    David Bell Guest
    Simply put ,it is a box that holds pitch,or tar, or a rubber product to seal a roof penetration.
    Ron Bibler's Avatar
    Ron Bibler Guest
    You hit the mother load with issue on the install of that pipe. limited support. banging each other. passing from one roof line into the next and then back out. Thats a mess.
    Hay Plumber Man...
    Best
    Ron
    Oklahoma City
    Dual purpose gas piping/lightning protection system. Maybe they are trying to blow up the house for insurance money. Did they have CSST running to all the appliances inside
    If it weren't for lawyers, we would never need them.
    Clint White Guest
    No CSST, just black iron Wrote it all up, buyers backed out (lotsa other juicy problems with the home).....Oh well....They still have another week to by a home and "win" $8000.....................
    Ron Bibler's Avatar
    Ron Bibler Guest
    Check out the way he ran the CSST Into the air handler for home.
    The agent say its no big deal. Can you see if this got a leak inside the ventilation system. gas being pump into every room inside the house and then at some point. KA-BLOWIES Up in smoke...
    Best
    Ron
