Thread: Washer drain line
05-02-2010, 09:51 AM #1
Washer drain line
Any reason a washer drain line should not be connected to the drain line after the p-trap?
The washer is in the garage directy behind the kitchen sink. The homeowners are doing a remodel and I was doing a pre-sheetrock inspecion and saw that the washer drain was connected to he kitchen sink drain line. I think it is okay but wanted to double check.
bm
05-02-2010, 10:54 AM #2
Re: Washer drain line
The washer should discharge with an air gap, not be plumbed directly into a pipe, especially downstream of a trap.
05-02-2010, 12:23 PM #3
I forgot to add that part; it had the air gap. With the air gap, in place , is it better for it to tie into the kitchen drain before or after the trap.
briam
05-02-2010, 12:33 PM #4
05-02-2010, 01:04 PM #5
05-02-2010, 01:42 PM #6
05-02-2010, 03:15 PM #7
05-17-2010, 03:06 PM #8
Laundry tubs and clothes washer drains are not supposed to be connected to kitchen sink traps. Don't know the code. But written in my I.T.A. plumbing book.
