    cglochau's Avatar
    cglochau Guest
    Default Help to identify
    Could anyone please explain this to me?
    Default Re: Help to identify
    Looks like some sort of heat exchanger.
    Maybe for heating water.
    Quote Originally Posted by cglochau View Post
    This was part of an old Heat Recovery System that utilized the Heat given off from your Air-Conditioner to heat water for your house.
    The Heat that an outside AC Unit usually puts into the air was instead used to make hot water.
    This System was abandoned and a newer style split AC system was installed.
    Similar to this Modern Version Free Hot Water: Sure, How? - Manufacturer Reports - Air Conditioning, Heating & Refrigeration NEWS
    cglochau's Avatar
    cglochau Guest
    Then is that where the extra piping for the hot water heater is going?
    Yes.
    That's Great, if you wanted to reinstall the newer version it should cut the Installation Cost.
