Results 1 to 2 of 2
Thread: Remodel
    RobertSmith's Avatar
    RobertSmith Guest
    Default Remodel
    Default Re: Remodel
    I'm sure those good ole boys down there at the Austin Building Dept. checked it all out well during the remodeling process.
    Must have had a green tag don't you think?
    Seriously hard to tell much from the pictures, but in picture #4 that 2x4 under the window frame is definately prone to some wood decay. Water running in from the outside from the fountain has to be causing some issues I would think.
    If the original patio pour was still used for the room enclosure and the above room addition, then I would definately recommend a SE.
    Any closer up pics?
