Results 1 to 35 of 35
Thread: Beat this:)
05-12-2010, 12:49 PM #1
Beat this:)
This was leading to an old, what looked like, WWII radio or transceiver.
05-13-2010, 07:31 AM #2
Re: Beat this:)
Found this hanging about neck level in the basement. The crumpled paper taped to it said, "Caution, Live Wire"
05-13-2010, 08:22 AM #3
Re: Beat this:)
Not bad, not bad at all
05-13-2010, 08:24 AM #4
Re: Beat this:)
Garage door opener connection.
05-13-2010, 08:36 AM #5
Re: Beat this:)
05-13-2010, 02:53 PM #6
Re: Beat this:)
I'll play. Here you go.
From my home inspection slaying's the last couple days.
Be sure and check out the "bong" in the child's room on the end table. WTF?
rick
05-13-2010, 04:42 PM #7
05-13-2010, 04:45 PM #8
Re: Beat this:)
What he really wanted to say was, nice bong.
05-13-2010, 04:57 PM #9
Re: Beat this:)
I like the living room.
05-13-2010, 05:47 PM #10
Re: Beat this:)
How many times has that kid fallen out that window??
05-13-2010, 06:10 PM #11
05-13-2010, 07:27 PM #12
Re: Beat this:)
From this mornings inspection! This is above a shower!
Also a picture of the garage! Just to keep Rick's folks from not feeling to bad!
05-13-2010, 07:41 PM #13
Re: Beat this:)
Scott,
Check out this light fixture. Its not within the shower space, but look out if you have a wet head (laughs a little) getting out of the shower.
rick
05-13-2010, 08:29 PM #14
Re: Beat this:)
Jimmy the water thermis be leakin again, where da dogs water bowl.
05-13-2010, 09:36 PM #15
Re: Beat this:)
But it LOOKS so good !!
05-13-2010, 09:37 PM #16
05-13-2010, 10:06 PM #17
Re: Beat this:)
OK,
Had to share too.
"Posts! We don't need no stinking posts!"
05-14-2010, 04:57 AM #18
Re: Beat this:)
I've been meaning to post this photo. So thank you for this thread.
Coffee container electrical box. The rest of the house wasn't much better!
05-14-2010, 05:42 AM #19
Re: Beat this:)
That one is going to be very hard to beat. LMOA.
05-14-2010, 07:05 AM #20
Re: Beat this:)
OK I found this yesterday, doesn't this just say love.
05-14-2010, 07:17 AM #21
Re: Beat this:)
Y'all need to post some of your "special" finds over on Home Inspector Facebook page... Welcome to Facebook | Facebook
05-14-2010, 07:31 AM #22
05-14-2010, 08:12 AM #23
05-14-2010, 09:59 AM #24
Re: Beat this:)
Homeowner said it's ok as long as it gets outside. Look at the wiring through the wall at the bottom right.
05-14-2010, 10:02 AM #25
Re: Beat this:) A return air vent!
For perfect circulation throughout the home.
05-14-2010, 02:57 PM #26
Re: Beat this:)
Humboltd County
05-14-2010, 06:51 PM #27
Re: Beat this:)
Today I found a opening that had been cut into a kitchen cabinetry to feed some cable wiring into the kitchen for a television on a counter top.
On the opposite side of this wall was a fireplace with metal firebox.
I held my camera over into the opening and snapped away. You can see the side of the firebox, but check out all the other things that was near this firebox.
One picture is a upshot of this area.
Last pic is supposedly roof repair.
rick
05-15-2010, 03:49 PM #28
Re: Beat this:)
I had to add this one, yes the conductors were live. I found this in a storage area.
05-24-2010, 02:28 PM #29
Re: Beat this:)
One thing about Jonathan Cartwright's garage door opener wiring: At least it is a dedicated receptacle...
05-24-2010, 05:52 PM #30
Re: Beat this:)
just plug it in!
05-24-2010, 05:55 PM #31
Re: Beat this:)
plumber? we don't need no stinkin' plumber!
05-25-2010, 03:24 PM #32
Re: Beat this:)
Who needs that factory made stuff!
05-25-2010, 06:47 PM #33
Re: Beat this:)
A thing of beauty today. High efficiency furnace with the condensate drain to the water heater pan, which of course went nowhere.
05-26-2010, 08:40 AM #34
Re: Beat this:)
Here's a couple.
The hot bus bar and breakers for the this panel are in the "updated" panel on the exterior of this wall.
The plastic in photo two is so the leaking fill valve wont spray water out from under the lid when it is in place. The tenant was pretty proud of this one.
05-27-2010, 03:23 PM #35
Re: Beat this:)
I thought I'd add what I can.
This is new wiring for the rooftop A/C. This was actually done by a local contractor.
