    dan orourke's Avatar
    dan orourke Guest
    Default Plumb vent near valley
    Default Re: Plumb vent near valley
    Being near the valley is not so much of a problem as it not flashed properly. I see some exposed nail heads too.
    Its a leaker if not already.
    Vent pipe doesn't appear to be painted either.
    Rick
    imported_John Smith's Avatar
    imported_John Smith Guest
    I agree with Rick. Its terribly flashed. Looks like amateur work. Could it be that a squirrel ate off the original flashing and the home owner covered it up with this Home Depot part.
    I wasn't aware of a requirement for painting vent pipe. I guess all the ones I see are covered. UV protection?
    Martin lehman's Avatar
    Martin lehman Guest
    Those Home Depot rubber gromets are a joke. These are a problem, not a solution.
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Where is it stated the PVC vent pipe must be UV protected (painted) I have only seen one or two painted and with in 1-3 years the paint is pealing off and looks like Hel_.
    The valley needs to be flashed to a min 18" from the center, roof penetrations closer than this compromise the flashing.
