Results 1 to 3 of 3
Thread: door landing?
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default door landing?
    Frank Kunselman's Avatar
    Frank Kunselman Guest
    Default Re: door landing?
    What does this door serve? If it's a pool equipment of mechanical closet, the I probably would not make an issue.
    If it is a path of egress then yes a landing, at the same level as the floor (1/2" difference), would be required.
    Try the door yourself and see if you don't trip or twist your ankle...remember not to look down since you know it's there.
    Martin lehman's Avatar
    Martin lehman Guest
    Door should not open out over a step. This is a trip and eat $&*$ hazard.
