Results 1 to 2 of 2
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default How to write this up
    john thurmond's Avatar
    john thurmond Guest
    Default Re: How to write this up
    Being that it is a low voltage system, and needs an outlet to plug into. I would simply explain to my client that it is an accessory being used for a specific application and I think they attempted to intall the system in an area out of the elements the best they could. If your client doesn't plan on using it. Simply unplug the device and problem solved. I also may mention that some municipalities prohibit the use of electric fencing in city limits. Check with your local municiple governing body to see if it is allowed. Good Luck.
