Results 1 to 2 of 2
Thread: Ground Wire
    allen elliott's Avatar
    allen elliott Guest
    Default Ground Wire
    Is stranded aluminum wire allowed to be used as the grounding conductor for the system ground? It is attached to a copper water pipe.
    Thanks for the help!
    Martin lehman's Avatar
    Martin lehman Guest
    Default Re: Ground Wire
    Are you sure its not a bonding jumper??
    If it is a ground I believe its required to be attached to the supply within 5ft upon entering the structure.
    Most of the time the bonding of the piping (water & gas) is done at the water heater.
    Oh and as far as usting stranded Al, I am unsure. However, I dont see what could be a problem...
    Last edited by Martin lehman; 07-06-2007 at 11:22 AM. Reason: forgot the original question..
