Results 1 to 13 of 13
    Austin, TX
    Default Water heater up in the air
    Does anyone have any other ideas where the code addresses accessibility to water heaters for this situation?
    <removed>
    M1305 Appliance Access comes to mind, but it could be argued that this is "accessible". However, you can't really have working space with a ladder in front.
    I would like to see steps and a full landing at least. Any insight would be appreciated.
    Default Re: Water heater up in the air
    Proper combustion/make-up air is a problem with that install as well!
    David McGuire's Avatar
    David McGuire Guest
    Thats different, never saw one with an exterior door.
    Austin, TX
    Actually, they had the high/low combustion air ducted in from the ventilated attic.
    Ft. Myers, FL
    Its like a giant brick trailer home.
    Paul Kondzich
    Ft. Myers, FL.
    Philip's Avatar
    Philip Guest
    As long as the high low air is met, then I can not see anything wrong with the installation.
    WARNING: l Clicked on the picture to enlarge and got a link popping up now to some porn site.
    But back to the water heater.
    The foam insulation on the water supply lines are too close to the exhaust draft hood. Needs a (6) in. min. clearance to combustibles.
    Okay now, back to the other link.
    rick
    "WARNING: l Clicked on the picture to enlarge and got a link popping up now to some porn site. "
    Was it good?
    rick
    Yup....same thing
    Jul 2007
    Got the same porno site here.
    The photo should be removed and reposted.
    Went to history file and found this is the site that is being seen.
    LiveJasmin.com - Amateur Webcam Shows - Free Live Sex
    Austin, TX
    reposted:
    sorry about that. posted it at a different site
    Ft. Myers, FL
    What about the TPRV pipe that appears that it is slid into PVC. If it is CPVC that would not be right either without a physical connection? Would it?
    Paul Kondzich
    Ft. Myers, FL.
    After 5 hours of having to watch that Jasmin video, I finally got the link removed from my computer.
