    Joe Asta's Avatar
    Joe Asta Guest
    Default Recessed Luminare Above Shower
    Does a low voltage (12VAC) recessed luminaire installed above the shower/ bathtub require GFCI protection?
    Default Re: Recessed Luminare Above Shower
    Quote Originally Posted by Joe Asta View Post
    Hello Joe,
    12 volt or 120 volt does not require GFCI protection.
    Sincerely,
    Corey
    Joe Asta's Avatar
    Joe Asta Guest
    Thanks for the replies.
    I replaced the 120V recessed can above my shower with a 12V 50 watt recessed can. I hooked up the primary leads (120V) of the transformer to the existing switched wires which get its power from the load side of a GFCI outlet. It works fine but I was just curious if it was a code requirement.
