Results 1 to 23 of 23
    Jon mackay's Avatar
    Jon mackay Guest
    Default Condensate trap too big?
    This condensate trap for an A/C connection seemed a bit too large but I wasn't sure if it was actually wrong.
    Is there a limit to the size?
    Default Re: Condensate trap too big?
    Jon,
    Ever try and push water uphill?
    Yes, its wrong.
    rick
    actually wrong.
    On So Many Levels.
    Mount Pleasant, SC
    Talking Re: Condensate trap too big?
    And leaking, it appears...
    www.atozinspector.com
    See attached:
    Attached Files Attached Files
    David Bell's Avatar
    David Bell Guest
    Very wrong, but probably works as the coil is probably about 4.5' off the ground.
    Apr 2008
    Western Massachusetts
    The Romans did it centuries ago. But unless that's intended to be an aqueduct yes, it's wrong.
    Ummm, size would appear to be the least of the problems. That's really a beautiful set-up. So do those pipes go down into a crawl? Looks like a great rodent highway.
    Nampa, Idaho
    It's all wrong, what it needs is a condensation pump with a drain line that is routed overhead and into the PVC drain pipe.
    Dec 2009
    Florida
    I tend to disagree with this "quick Fix". My experience with condensation pumps is that it's another point of failure. They tend to quit a lot, and its usually an item that may be looked at one a year if you are lucky. This should be a last resort if a good condensation gravity system can't be installed.
    Aug 2009
    Minnesota
    Besides the length of the drain 'trap"; Isn't a condensate trap supposed to have an air gap(?) and not be directly connected to the sanitary sewer?
    jason schatz's Avatar
    jason schatz Guest
    Quote Originally Posted by Jane Slaughter View Post
    was thinking the same thing --- until I saw what looks like a cleanout is actually an AAV...
    Apr 2008
    Quote Originally Posted by jason schatz View Post
    an AAV is not an air gap, it does nothing for backflow prevention
    jason schatz Guest
    you're right, my fault...
    Does condensate water qualify as cross connection to portable water?
    Apr 2008
    Potable water contamination is one but not the only reason to have a backflow/backpressure preventer.
    jason schatz Guest
    seeing as there is no potable water connection at the heater, I'd say that'd be a no....
    But sewage backflow...even if it were just gases...wouldn't be a nice scene in the air flow of the unit.
    David Bell's Avatar
    David Bell Guest
    The requirement for condensate is much the same as effluent, trapped at the closest place and subject to venting requirements.
    Sep 2008
    Texas
    Where is the specification that the horizontal piece of a trap cannot be 6"...12" or even 96" on a condensate line.
    I looked at the links provided and all that was specified was height requirements. Nothing about from one vertical to the other.
    Please educate me.
    David Bell's Avatar
    David Bell Guest
    The condensate piping by itself is only subject to condensate guidlines. But once you connect that to a homes DWV system, it must adhere to all codes and regulations that all piping in that system conforms to.
    Sep 2008
    Texas
    Okay....so you are saying what?
    David Bell's Avatar
    David Bell Guest
    The trap lengths and heights are subject to plumbing codes
    WRT the necessity of traps on the suction side of air handlers, this may be of interest:
    Condensation in ceiling - Contractor Talk HVAC forum
