    Jon mackay's Avatar
    Jon mackay Guest
    Default Floor Drain Backup
    At a home in city limits, if the area around a floor drain is very wet indicating a backup, what would you advise?
    If its backing up, it is likely from the storm drains correct?
    Would you call the city utility?
    Nov 2007
    Default Re: Floor Drain Backup
    Floor drains do not connect to storm drains. They are part of the buildings sewer system.
    If it has backed up during a heavy rain, it is best to call the city and ask them if their sewers are flowing. If it is not a city sewer issue, then you will need to hire a drain cleaner.
    New Mexico
    Break out a garden hose on a day it's not raining, and see what happens. If it backs up, then you'll need to get a drain snake in action. Hopefully, it's just a clog and not a larger problem. You probably can't see where it terminates, which would be helpful. Some of them run to a French drain, others to the sewer, and some will drain to daylight.
