    Wade Johnson's Avatar
    Wade Johnson Guest
    Default Electrical panel
    Good morning. What is happening when some of the breakers in a panel are warm or even hot to the touch?
    Default Re: Electrical panel
    Heat is generated by the current flowing through the breaker. This heat is what causes a breaker to trip on overload.
    Abnormal levels of heat could point to a problem.
    Were they AFCI breakers?
    Heat is generated by the current flowing through the breaker. This heat is what causes a breaker to trip on overload...
    Well, at least in many modern designs, not exactly, see for example:
    HowStuffWorks "Basic Circuit Breaker Design"
    Mar 2009
    Colorado Front Range
    Most all breakers of modern manufacture (that you're likely to find in a residence) have both a magnetic and thermal component to the trip mechanism.
    An illustration that does not reflect actual trip curves but illustrates the point is a 15 AMP breaker may carry 16 Amps for many hours before tripping, but will trip much sooner with a 30 AMP load.
    The magnetic component makes for instant tripping when a fault occurs.
    Older breakers may lack the magnetic component
    Quote Originally Posted by Wade Johnson View Post
    If there were lots of high intensity lights on for a long time, it might explain the problem. A Zinsco/Sylvania panel might be arcing at the buss bar connection. I would defer and have an electrical contractor look at it.
    Jon mackay's Avatar
    Jon mackay Guest
    I had an electric water heater turn on while I was inspecting a panel and the 30 Amp breaker heated up to about 100 degrees.
