Thread: PVC exhaust
    Jun 2007
    Farmington, MN
    Default PVC exhaust
    Got about an 8 yr old furnace with a PVC intake/exhaust. It looks like when they installed it the exhaust PVC didnt line up perfect so they instead of redoing it fitted with a rubber splice boot with the metal wrap around it. Basically two screws holding it on. I dont like it. Chance that it could get bumbed or come off over time. Obviously neither would be a good situation. Anyone know if this is allowed? I would think a solvent welded connection would be mandatory from the furnace to the exterior.
    Lanny Freng
    Inspection WerX
    "Get the Best of US before your new home gets the best of YOU!"
    Default Re: PVC exhaust
    Can't really imagine that it is allowed. Never seen any install manuals that discussed it. Due to the acidic nature of the exhaust product erosion of the rubber over time would be likely.
    Never seen such an install either.
    David Bell's Avatar
    David Bell Guest
    As long as the connector does not inhibit the condensation flow back to the unit, it should not pose a problem. Many manufacturers have a boot that is used at the connection to the vent fan, they have a drainage port built into them but, also serve as a vibration isolator.
