Results 1 to 13 of 13
    Jon mackay's Avatar
    Jon mackay Guest
    Default Over Exposed Shingles
    Are these shingles installed too far apart or is it just an odd shingle pattern?
    Texas
    Default Re: Over Exposed Shingles
    Looks like over exposed to me. Were you able to lift a shingle up and see if there was any sealant under the tab?
    Jon mackay's Avatar
    Jon mackay Guest
    No, they were all stuck down pretty good. The roof was around 10 years old.
    I see an interrupted thick faux shadow line. Architectual shingle. No scale what was the exposure, did you measure it?
    Looks normal to me. I agree, like an intentional faux shadow line.
    Jon mackay's Avatar
    Jon mackay Guest
    I did not measure it.
    The applique layer seemed to align ok, but it was just an odd look.
    Are shadow lines common? Does anyone have an example from a manufacturer?
    Another vote for: looks normal to me, and is a shadow line.
    Here's an example of a similar (if not same) architectual shingle on the right, and a standard 3-tab on the left.
    (click on photo to enlarge).
    HTH
    Sep 2009
    Twin Cities, Minnesota
    Owens Corning has a bunch of those "shadowed" architectural shingles:
    Owens Corning Roofing: Browse Owens Corning Shingles
    (scroll down a little bit)
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Quote Originally Posted by Jon mackay View Post
    Yes.
    You'll find loads of examples. Type "Architectual Shingle" at your favorite web search engine (Yahoo, Google, MSN, etc.), I'm sure you'll find example links to manufacturer names you recognize.
    Jon mackay's Avatar
    Jon mackay Guest
    Ok, thanks for the info.
    That makes sense..
    Texas
    Never seen this type of shingle. Guess you can always learn something.....
