Results 1 to 2 of 2
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Chimney stucco flashing on tile roofs
    Default Re: Chimney stucco flashing on tile roofs
    If you see many tile roofs, collect some install guides from the various roofing tile manufacturers that the local builders use.
    There are many details not visible once the roof is complete.
