    Alan C Grubb's Avatar
    Alan C Grubb Guest
    Default Help with basement drainage tiles
    This was new to me. They had an opening in corner where the drainage tiles came together and at one time had a some type of accumulation device, which has disintegrated. Anyone give me a better understanding of what is going on here?
    Default Re: Help with basement drainage tiles
    Quote Originally Posted by Alan C Grubb View Post
    It appears to be an abandoned sump pit.
    There would normally be a pump in there and a lid on top.
    Sep 2009
    leonardo, new jersey
    I agree with sump pump pit, theres a large corrugated pipe buried in there and the mason took a 5 gallon spackle bucket to cover it and stop the concrete from pouring in
    Joseph Ehrhardt
    Andrew Christel's Avatar
    Andrew Christel Guest
    Sink Hole.!!
    Looks like a abandon sump pit.
    Joao Vieira's Avatar
    Joao Vieira Guest
    My 2 cents:
    you should come back or recommend follow up while during rainy weather.
    If there is still visible water flowing it's possibly a disaster waiting to happen.
    Sometimes the lack of maintenance makes things look abandoned or the other system installed could not be working as planned.
    Jan 2010
    sellersburg, in. work in lou, ky.
    Was this an older home that appeared to have newer concrete poured in the basement??
