Thread: A First For Me
    Jun 2008
    St. Thomas Ontario, Canada
    Default A First For Me
    Comments Please:
    Default Re: A First For Me
    Do you have pics of the gable ends? Older pre-70's home? That looks like a style that we see up here sometimes, an attempt to make a shingle roof look like an English thatched roof. The old T-locks worked better for that, but (sniff) they're also a thing of the past.
    Jun 2008
    There ya go!
    chris mcintyre's Avatar
    chris mcintyre Guest
    That is crazy looking but as long as the sheathing and those first few runs of shingles meet the installation requirements, IMO it is OK.
    Ron Bibler's Avatar
    Ron Bibler Guest
    The shingles need support. voids the warranty of the roof. did you see any water stains. and there are water stains I bet some place around the overhangs. this is a poor install and needs to be corrected...
    Best
    Ron
    The first set of photographs appear not to be what was intimated by a later poster a rolled eave (rolling eave, radius eave, wrapped eave) appliaction, but a modified BELL type roofing application, note the flare and edge termination(s), which would be more in keeping with the tropical or subtropical location.
    Obviously there are issues with improper installation, and a significant problem at the valley.
    A rolled eave, or wrapped eave installation requires more skill and is slightly more difficult and less forgiving than a bell roofing installation although there is much in common.
    An experienced roofing professional, shingle manufacturer's installation instructions, and sometimes manufacturer's representatives, in these type installations should be consulted. Installation errors tend to void manufacturer's warranties. Shingle manufacturer's installation instructions, technical specifications, etc. limit and have specialized requirements regarding low slope and high slope, radius, orientation, applications for their roofing system materials.
    Obvious defect is pictured in first photograph posted in need of remediation.
