    dan orourke's Avatar
    dan orourke Guest
    Default Thank the lord......
    Smile Re: Thank the lord......
    They have some serious venting issues. Look at the disoloration. Also, where is the draft hood connector? I don't even see any screws.
    The manual should remain with the unit. If it is damaged then state it should be replaced.
    Default Re: Thank the lord......
    In addition to what Bob H. said, that flexible copper line 'is reduced in size' and should not be used for the T&P discharge drain line.
    If you put photos in your report, that would be a good one to put in there.
    Bob H., question for you: Are those nylon/Teflon/whatever-type-plastic pieces in those flexible line connections allowed that close to the draft hood/vent? I've always been curious about that.
